GPFORCE/SPCForce
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
request for the reaction force output to see it in the HV/HG result types menu. In Optistruct, I activate GPFORCE from GLOBAL_OUTPUT_REQUEST & also in loadstep activate Analysis,Output as a displacement,stress and GPFORCE option.Finally I ran the NLGEOM analysis and trying to see the results in hyperview,but  i am unable to see the GPFORCE in result types menu.Please suggest the solution.
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited December 2014
    Hi tusharpatil123
    Please refer to the image below from Help about supported solution sequences for GPFORCE:
    Please note: If you are a commercial customer, you can contact your local support for a quicker solution http://www.altairhyp...ortProduct.aspx
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-99611700-1419232343_thumb.jp
  • Altair Forum User
    Altair Forum User
    Altair Employee
    As per you suggested i use the OP2 format for NLGeom static analysis, i am able to see only the stress and displacement plot but unable to find exact force through GPFORCE command. Please suggest the solution in proper step.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Please sir suggest the solution.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Tushar,
    GPFORCE is not supported for NLGEOM,
    Instead you can run NLSTAT.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    hi Prakash,
    could you tell me an option for Geom non-linear analysis where i should get a GPFORCE-Displacement diagram? with Nonlinear quasi static i can not solve because of contact.
    Thanks in advance!
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Hi,
    GPFORCE output is available for the following solution sequences:
    Solution Sequence
    Static Analysis
    H3D, OP2, PCH, OPT
    Normal Modes Analysis
    H3D, OP2, PCH
    Direct Frequency Response Analysis
    H3D, OP2, PCH, OPT
    Modal Frequency Response Analysis
    H3D, OP2, PCH, OPT
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    You can run the NLGEOM analysis which will write out .rad files. Use these files in RADIOSS to request reaction forces using output blocks.
Welcome!
Welcome!
