🎉Community Raffle - Win $25
Join and Win
high time for assign existing property
User: "Sergio DELL'AMICO"
Altair Community Member
Updated by Sergio DELL'AMICO
Hi
We are testing the 2023 Hypermesh and we are compaing it to 2017.2.
We have seen that for the same object when we assign existing property from utility tab for moldflow it takes 6 times more (5 min with 2017, 30 min with 2023)
We use a very simple part to check the difference (2 little plane connected).
This test was done with the mesh generated with 2017.
If we create the mesh in 2023 we have longer time.
Thanks
Sergio
1 - 1 of 11
    User: "Jason_Craanen"
    Altair Employee
    Updated by Jason_Craanen
    Dear Community,
    The extended time for property assignments in Moldflow 2023 is a result of limited updates and maintenance on certain functionalities. We are aware of the performance issues this may cause and are exploring ways to enhance the efficiency of this process.We appreciate your understanding and are dedicated to improving our software to support your needs.
    Best regards, Joe Kovacs Vice President - Modelling & Visualization Altair
