Hi
We are testing the 2023 Hypermesh and we are compaing it to 2017.2.
We have seen that for the same object when we assign existing property from utility tab for moldflow it takes 6 times more (5 min with 2017, 30 min with 2023)
We use a very simple part to check the difference (2 little plane connected).
This test was done with the mesh generated with 2017.
If we create the mesh in 2023 we have longer time.
Thanks
Sergio
