How can I run multipal pressure case in Hyperworks CFD?
Barnabas Retter
Barnabas Retter Altair Community Member
edited January 2023 in Community Q&A
Hi All!
I would like to ask, how can I solve multipal inlet pressure cases in 1 simulation? I attached the pressure cases, on the x axis there are the different pressures and on the y axes the neccessary volume flow rate ( this is what i want to know after the simulation)
Answers
  • ydigit
    ydigit
    Altair Employee
    edited January 2023
    DOE for CFD is possible with SimLab 2022.1 onwards.
    Does that help you or you need it in HWCFD?
Welcome!
Welcome!
