Hi All!
I would like to ask, how can I solve multipal inlet pressure cases in 1 simulation? I attached the pressure cases, on the x axis there are the different pressures and on the y axes the neccessary volume flow rate ( this is what i want to know after the simulation)
DOE for CFD is possible with SimLab 2022.1 onwards.
Does that help you or you need it in HWCFD?
