🎉Community Raffle - Win $25
Join and Win
Generating 60nm thickness along the grain boundaries of a microstructure
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I generated a microstructure (5 x 5 x 2 micrometer)  using Abaqus input file (attached).  But the microstructure does not have
grainboundary thickness.
I would like to generate thickness (60nm) along the grain boundaries using hypermesh.
Could you help me generating 60nm thickness along the grain boundaries?
Thank you
 Operating System and Version:                Windows 10
1 - 4 of 41
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Your grain boundaries cover whole microstructure? And you want to make them as solid elements?
    If I understand correctly, here's my test:
    Create external skin of all 3 components:
    Got '^faces' :
    Make solid elements by 'elem offset' :
    And got final layer boundary :
    Is that you're looking for ?
    Altair Employee
    OP
    Q Nguyen-Dai
    Thank you very much for your suggestion.
    Based on your figure, we are not sure whether you understood our definition of grain boundary thickness.  So I attached a picture showing the grain boundaries(GB) in white color.  I think the GB can be modeled either shell or solid.
    Also. I tried your method.  But, after clicking 'offset' button, E_boundary was not created (Nothing happened).
    Thank you.
    <?xml version="1.0" encoding="UTF-8"?>4grains_with Grainboundary_indicated_by_white.png
    That's simpler with shell.
    Just create external surface for each solid component.
