Altair RISE
Nominate Yourself Now!
nastran interface
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear sir, I exported hypermesh to nx nastran solver. Everything is correct and problem also solved. But I can't get the results file? Plz help me how to get??
1 - 9 of 91
    Altair Employee
    OP
    Hi Shreeharsha,
    what do you mean by result file?
    When you export from HyperMesh you get a solver deck.
    Altair Employee
    OP
    Results are not found it showing??
    Altair Employee
    OP
    Have you solved the job on NASTRAN?
    Altair Employee
    OP
    I solved. First I have done with your hands on model I got the results. But for my model it is showing results are not found in nx nastran environment??
    Altair Employee
    OP
    @shreeharsha: why not use Siemens CAE NX for this job? You can make the mesh, BC,...and post-process the results too.
    Altair Employee
    OP
    Hi Shreeharsha,
    HyperMesh can only pre-process the model for Nastran nx,
    If the results are not created after solving from Nx Nastran,  Please contact nx Nastran support for your issue.
    Altair Employee
    OP
    Hi Shreeharsha,
    In your Input data, try this parameter:
    PARAM,POST,-1
    By this way, you will got OP2 results file. Hyperview can load this format. I just tested it, that's ok.
    Altair Employee
    OP
    Hi Shreeharsha,
    Hi Prakash Pagadala,
    Yes, I see the support for NX Nastran of Hypermesh, but that's not completed for this moment.
    One special feature of NX Nastran is supporting Pyramid elements. But with current Hypermesh FEoutput template, we can not output CPYRAM elements. I have to do that with my customized template.
    Maybe, in the future release of Hyperworks we can wait for a new profile 'NX Nastran' ? Could you ask developpers for this point ?
    Thanks
    Altair Employee
    OP
    Hi Q.NGUYEN-DAI,
    An RFE was already reported to included support for CPYRAM elements.
    I hope this will be available in coming version image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
