🎉Community Raffle - Win $25
Join and Win
Stress in steel sleeve assembled with a pressure fit on a steel shaft.
Boris_22428User: "Boris_22428"
Altair Community Member
Updated by Boris_22428
Hello Everybody !
I need to check the stress in steel sleeve (tube) assembled with a pressure fit on a steel shaft.
Can I do it with linear static ?
(I saw a video on YouTube with quasi-static load step and very complex SPCs that I did not understand)
Can you please prompt me a best way, any tutorial or video ?
Thanks a Lot !
1 - 4 of 41
    Adriano_KogaUser: "Adriano_Koga"
    Altair Employee
    Accepted Answer
    Updated by Adriano_Koga
    hi @Boris
    You need to run NL Quais-Static analysis for this.
    You can do this 2 wyas:
    1) checking only the press-fit, and letting the solver "remove" the penetration in the contact
    2) running the insertion from the beginning, calculating all the steps.
    There are a few models attached, that i hope might be helpful, for option 1).
    If you want to run #2, then LGDISP and CONSLI Contact should be used, with a well discretized mesh.
    If you're not familiar to OS NL analysis, i recommend you to go through the Altair University training materials first.
    SPC/SPCD define the enforced displacement for the solver.
    For a SPCD 2.0 in Z direction, you need to add also a SPC 0.0 in the same DOF.
    OP
    Dear Adriano
     Thank you very much for your reply and for attached models (I just have run them) !
    is the difference between them - only the SPC thru the RB at z direction ?
     The clearance -5 in contact is the press fit of 5 mm on radius (and 10 mm on diameter ?)
    I did a couple examples from OptiStruct tutorials, but of cause I need to learn more..
     Your examples are of way 1 ? can you please give some more tips for each way ?
     Thanks a lot !
     Boris
    Dear Adriano
     Thanks a lot !
     Boris
    one of them is just a static cylinder subjected to the press-fit, already inserted. I've added the negatice clearance to numerically impose the value of penetration in this model, independently on the mesh distance. Correct, -5mm in radius (10mm total).
    The second one, name rotation, I've applied also a rotation in the rotation dof, by using the SPC, and imposing some angle of rotation (value in radians).
    OP
    hi @Boris
    Dear Adriano
    I have a pressure sleeve that secures glued magnets on the rotor.
    I know how to find the stress with RFORCE. Now I need to combine RFORCE with Press fit (to check the effect of safety sleeve on magnet's glue stress )
    I tried to base on these files, you kindly shared here, (with IR4NLCON - inertia relief for nonlinear), But there was no convergence.. just errors..
    Will be grateful for any tips !
    Thank You and Best Regards
    Boris
