1 - 2 of
21
you need to check your model. No mode was found in this range, thus no results generated
ANALYSIS RESULTS :
ITERATION 0
*** WARNING # 3917
No mode exists in the interval specified.
subcase ID = 1
minimum frequency = -1.0000e+01
maximum frequency = 1.0000e+04
(Scratch disk space usage for starting iteration = 72 MB)
(Running in-core solution)
Volume = 1.81355E+05 Mass = 1.42364E-03
Generalized Generalized
Subcase Mode Frequency Eigenvalue Stiffness Mass
ANALYSIS COMPLETED.
Hi Amzar,
The .h3d file is missing in the folder. That message is given by hyperview when you are trying to open the file. Please rerun it.
Thanks
Rajashri
