Hi all,
As per the above title, currently I have problem with my Hyperwork OptiStruct analysis. I hope I can get answers to my problem here as soon as possible. I also attached the picture and the zip file of my problem.
Hi Amzar,
The .h3d file is missing in the folder. That message is given by hyperview when you are trying to open the file. Please rerun it.
Thanks
Rajashri
you need to check your model. No mode was found in this range, thus no results generated
ANALYSIS RESULTS :------------------
ITERATION 0 *** WARNING # 3917 No mode exists in the interval specified. subcase ID = 1 minimum frequency = -1.0000e+01 maximum frequency = 1.0000e+04 (Scratch disk space usage for starting iteration = 72 MB)(Running in-core solution)
Volume = 1.81355E+05 Mass = 1.42364E-03
Generalized Generalized Subcase Mode Frequency Eigenvalue Stiffness Mass
************************************************************************ ANALYSIS COMPLETED.
