The Electrostatics Model of EDEM 2023
When I use the electrostatics model of EDEM 2023, is the electrostatic force between the particles and the geometry calculated? Also, is the electrostatic force between the particle and the geometry calculated based on the image force? If not, how do I add the image force of the particles and the geometry?
Thanks for a lot.
