import IGES into hypermesh and make as solid
Hi
I am trying to import IGES and make as solid.
After I imported the geometry,
Geometry tab -> solids-> Go to model tab -> right click components -> make current
Under solids -> Surfs-> by collector-> select component -> create
I followed procedure above and when I used v11, the procedure worked well, but now I use v12 and it does not work anymore.
Is there any other way to make geometry as solid in v12 or should I modify any settings for the recently installed hypermesh?
I would appreciate any help.
Thanks,
Jay
