🎉Community Raffle - Win $25
Join and Win
Importing NASTRAN FEM and combining with .gda FEM
User: "darad"
Altair Community Member
Updated by darad
I imported a NASTRAN bar (beam) model into SimLab, as a *.dat model with a dozen bar element bodies therein.
I wanted to connect this beam element model with a FEM within an assembly.gda, but the *.dat cannot be dragged directly into assembly.gda
However, if I create a submodel in assembly.gda, the *.dat model can be dragged into the submodel.
Although the beam model and FEM's are all within the assembly.gda, they cannot be connected by RBE or Join, with Warning they are not in the same model.   Apparently, there is not way to connect a NASTRAN model with FEM's within an assembly.gda.
1 - 1 of 11
    User: "Kamalraj"
    Altair Employee
    Updated by Kamalraj
    Hi, select all the bodies in the both models and click on Geometry > Model > Merge Icon. I will collect all the sele cted bodies and will place under a single model. <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.3792e2a4279e54b21b6671286af95cc1.png
