🎉Community Raffle - Win $25
Join and Win
Set Animation Mode in Hyperview
User: "Emil George"
Altair Community Member
Updated by Emil George
Hi,
I am trying to change the animation mode in hyperview to 'Set Modal Animation Mode' using tcl command.will be great  if some can help me out.
Thanks in advance
Regards,
Emil
1 - 3 of 31
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    Hi Emil,
    Please try the 'hwIPage SetAnimationMode'.
    The sample code is following.
    set t [::post::GetT];
    hwi OpenStack;
    hwi GetSessionHandle sess$t;
    sess$t GetProjectHandle proj$t;
    proj$t GetPageHandle page$t [proj$t GetActivePage];
    page$t GetAnimatorHandle anim$t;
    page$t GetWindowHandle wind$t [page$t GetActiveWindow];
    page$t SetAnimationMode modal;
    Thanks,
    Imoto
    User: "Emil George"
    OP
    Thanks a lot Imoto.. It worked perfectly.
    I would like to get one more help.I am looking for a tcl command by which I will get a zoomed image/ animation of the area at which the displacement or stress is showing max value.
    for instance, I am able to the displacement contour of a model , then look for the max displacment node, show only the particular part at which max value is showing  and save the gif file of the same. but apart from this I am looking to get another image/gif file after zooming into the area max displcament.
    For the last step I am not able to get the tcl command.
    Your help is appreciated.
    Regards,
    Emil
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    Hi Emil,
    In my recomendation, you should use the ARD (Automated Reporting Director), which is a part of PSO solutions.
    ARD has the all feature you are looking for.
    Please visit our website.
    https://altairhyperworks.com/product/automated-reporting-director?__hstc=239203932.4b3c176b4de93a8890046fdef4b286ae.1527155885988.1527155885988.1527155885988.1&__hssc=239203932.3.1527155885988&__hsfp=827660387&_ga=2.176241893.111535606.1527155884-1761386969.1527155884
    Thanks,
    Imoto
