I am trying to change the animation mode in hyperview to 'Set Modal Animation Mode' using tcl command.will be great if some can help me out.
Thanks in advance
Emil
Hi Emil,
Please try the 'hwIPage SetAnimationMode'.
The sample code is following.
set t [::post::GetT]; hwi OpenStack; hwi GetSessionHandle sess$t; sess$t GetProjectHandle proj$t; proj$t GetPageHandle page$t [proj$t GetActivePage]; page$t GetAnimatorHandle anim$t; page$t GetWindowHandle wind$t [page$t GetActiveWindow]; page$t SetAnimationMode modal;
Thanks,
Imoto
Thanks a lot Imoto.. It worked perfectly.
I would like to get one more help.I am looking for a tcl command by which I will get a zoomed image/ animation of the area at which the displacement or stress is showing max value.
for instance, I am able to the displacement contour of a model , then look for the max displacment node, show only the particular part at which max value is showing and save the gif file of the same. but apart from this I am looking to get another image/gif file after zooming into the area max displcament.
For the last step I am not able to get the tcl command.
Your help is appreciated.
In my recomendation, you should use the ARD (Automated Reporting Director), which is a part of PSO solutions.
ARD has the all feature you are looking for.
Please visit our website.
https://altairhyperworks.com/product/automated-reporting-director?__hstc=239203932.4b3c176b4de93a8890046fdef4b286ae.1527155885988.1527155885988.1527155885988.1&__hssc=239203932.3.1527155885988&__hsfp=827660387&_ga=2.176241893.111535606.1527155884-1761386969.1527155884
