Altair RISE
Nominate Yourself Now!
TCL: how to translate coordinates from a system to another?
User: "Stéphane Combet"
Altair Community Member
Updated by Stéphane Combet
Hello,
Being new to tcl, I manage to get coordinates of grid selected by user with *createmarkpanel and hm_nodevalue.
What about translating coordinates in another coordinate system? Is that implemented in a given function or should I write a script for that?
Thank you!
1 - 5 of 51
    User: "Michael Herve"
    Altair Employee
    Updated by Michael Herve
    Hello again @Stéphane Combet,
    Do you want to apply translation of a node selection along the axis of a user-defined system?
    If so, *translatemark request a vector. You can retrieve the command to create this vector from command.tcl.
    Then for getting the direction of the system, you may query for system attributes through hm_getvalue
    The attributes for a given entity can be retrieved in online help (search for data name) or from Matrix Browser, see below an exemple (for materials) from 6:30:
    https://youtu.be/OGRMJLunkrs?si=lW8srqNsmJUlRhBB
    Does it help?
    Michael
    OP
    Does it help?
    Michael
    Thank you Michael,
    Not sure this helps. What I want is not to move the node. But a given node being placed at (0,0,0) in global coordinate system, if I have another rectangular system placed at (1,1,1) parallel to the global one, the coordinates of the very same node are (-1,-1,-1).
    I wonder if there is a function to get those coordinates of a node in such another system (my case being obviously more complex with systems not parallel to global one).
    If not, I will have to code myself the formulas. Feasable, but so boring... :'(
    Altair Employee
    Thank you Michael,
    Hello again @Stéphane Combet ,
    if you want node coordinates in a user defined system, first you need this user system to be assigned to your nodes. This way, you can use the following command:
    set localX [hm_getvalue node id=$NodeId dataname=localx]
    set localY [hm_getvalue node id=$NodeId dataname=localy]
    set localZ [hm_getvalue node id=$NodeId dataname=localz]
    Is it what you are looking for?
    Best Regards,
    Michael Herve
    OP
    Best Regards,
    Michael Herve
    Thank you! Ok so I could:
    1. assign the user defined system to the node
    2. use the command you gave me to obtain coordinates in user defined system
    3. re-assign previous system to the node
    I will look for a command to assign a system to a node.
    Altair Employee
    Hello @Stéphane Combet ,
    your process is correct.
    You should be able to use these commands:
    *createmark nodes 1 selection_method
    *systemsetanalysis nodes 1 $systemid
    Then to reset you can use:
    *systemsetanalysis nodes 1 0
    Regarding the attributes to query for local coordinates, I need to apologize, here are the correct syntax (I just tested it back this morning):
    set localX [hm_getvalue node id=$NodeId dataname=x]
    set localY [hm_getvalue node id=$NodeId dataname=y]
    set localZ [hm_getvalue node id=$NodeId dataname=z]
    or
    set LocalCoords [hm_getvalue node id=$NodeId dataname=localcoordinates]
    In this second case you get a list with x y and z coordinates.
    Best Regards,
    Michael
