🎉Community Raffle - Win $25
Join and Win
Tet Collapse Problem
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi everybody.
I'm starting mesh a skid loader frame, in which there are some thin thikness. I have a problem about meshing this frame. I'd like to use tetra mesh command, so I meshed the surfaces by automesh and then I realized the 3d mesh by 'tetra mesh'. The final mesh often presents problem with tet collapse parameter and I noticed that if there are some elements with tet collapse < 0.1 I can't launch the analysis in Optistruct.
So I guess:
Is it possible that if  there is only an element that fails tet collapse check the analysis does not run?
May I launch the analysis in any way?
If not, how can I optimize the mesh for structural analysis in Optistruct?
I suppose that tet collapse failure elements can depend by thin thikness...
Thanks in advance.
Best regards
1 - 2 of 21
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi Stefano,
    By Tetra remesh you can try for improving mesh quality or manual method if failure of tet collapse is less in number.
    Optistruct allows PARAM CHECKEL NO which would not check the element quality during analysis.
    Altair Employee
    OP
    Hi Rahul
    Thank you very much.
    By tetra remesh I solved the problem.
    Best Regards
