Contact type 7
Good afternoon,
I often find out that contatct type 7 drives the simulation to error due to negative or null time step.
Attached to this message there's a picture that shows what usually happend in this case: there's a rounded surface that grawls over an edge surface, the consequence is that the master surface grabs a node from the slave surface (or vice-versa) causing an eccessive deformation of an element of the mesh, so the time step becomes very small.
I'm I doing something wrong? Is there a way to improve the contact characteristics to avoid time step decrease?
Thanks for helping me
Well,
First of all I shall advance that I'm currently using release 12, I hope we'll soon be able to install version 14, but unfortunatelly it is not possible to use the option Irem_gap.The model doesn't undergo self impact. Anyway I used contact type 7 though the master surface is a rigid body surface made of steel and the slave set nodes is taken from a tetrahedron elements mesh made of PP
Due to your suggestions I changed the interface definition as follows:
contact
# Slav_id Mast_id Istf Ithe Igap Ibag Idel Icurv Iadm
1 33 4 2 1
# Stmin Stmax %mesh_size dtmin Irem_gap
1.00000000000000E-08
# Stfac Fric Gapmin Tstart Tstop
0.3 0.55
Please provide IGap value while Type 7 interface is applied. If Igap is already provided, sligtly increase the value and see.
Because of unusual element deformation, the time step is dropping drastically in this case and it may finally end up in error after running for a long time. Moreover please see the correct loading conditions (imposed / initial) are selected.
Please let us know whtr it worked / not
