Edge to surface sliding contact
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
How to define a contact between edge to surface? I tried using CONTACT with sliding but somehow it is not working.
Welcome!
Answers
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited June 2016
    Which version of Hyperworks you are using?
  • Rahul Rajan_21763
    edited June 2016
    You can try this  simulation in Radioss also.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2016
    I am using HM 14.0
    I have hardly used RADIOSS before.
  • Rahul Rajan_21763
    edited June 2016
    could you share us. fem file?
  • Rahul Rajan_21763
    edited November 2020
    Thanks for sharing files.I see you have not defined NLPARM card. Just define NLPARM card with Ninc & max iteraion with default setting. Set loadstep to NLSTAT & run analysis.
    Attached is the updated file with updated Rforce.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2016
    Thanks a lot for the help Rahul. It is now a little better to proceed with my analysis. However, I have one more doubt. For large displacement what parameters do I have to play with when using NLPARM card? I mean that I want to rotate the shaft by almost 180 degrees. I tried giving high rotation velocity but that doesn't help.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2018
    Have you won this problem, Friend?
    i try to solve issue edge to surface contact too, but my task is on shell mesh.
Welcome!
Welcome!
