hello, i am a beginner for motion view, i am trying to do simple spur gear simulation in motion view, but i dont understand how to give input in the form of rpm,torque on pinion to get in same form as output on gear,
Hi Ravi,
You can provide angular velocity on the revolute joint (for example) and request velocity from the pinion rev joint.
