Altair RISE
Nominate Yourself Now!
Multithreading in HM2017
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I am trying to implement Multi-threading in HM 2017 using TCL to compute faster results.
Is it possible with HM2017 after adding Thread package to its tcl.
Thanks in Advance, for help.
Regards
Piyush
1 - 9 of 91
    User: "tinh"
    Altair Community Member
    Updated by tinh
    which results do you want to calculate?
    it is possible to create threads but i don't think they can access hm database
    creating threads is simple, but dividing jobs may be tough
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Are you speaking about Solver?
    For Hypermesh (Pre-Post) I don't think you can do something about this: either works, either does not work, that's all.
    Altair Employee
    OP
    Dear @tinh and @Q.Nguyen-Dai,
    1. I need to import a model and then extract its geometry in threads. Like I need to extract Faces , Edges & Elements in parallel threads to save time.
    2. I also wan't to display a GUI, which goes into 'not responding' loop while long calculations. So I want to display this GUI using one more parallel thread.
    (P.S. : Not able to Display GUI in threads using HM. Whenever I source my GUI file, it does not display any GUI, but in Main Thread, its working fine.)
    Is it possible with Hypermesh 2017 ?
    Thanks for help.
    Regards
    Piyush
    User: "tinh"
    Updated by tinh
    what do you mean by 'extract face, edge, elem' ?
    could you give an example?
    Altair Employee
    OP
    Dear @tinh
    1. Import Geometry file in Hypermesh
    2. This Step is Divided into 3 steps (using Multithreading)
    2.1  eval *createmark elems 1 all;  set 3d_elems [hm_getmark elems 1];
    2.2 eval *createmark elems 1 all;  *findfaces elems 1; eval *createmark elems 2 'by collector name' '^faces';  set 2d_elems [hm_getmark elems 1];
    2.3 eval *createmark elems 1 $all ;   *findedges elems 1 0;  eval *createmark elems 1 'by collector name' '^edges';  set tempp [hm_getmark elems 1];
    I need to complete this 2nd step using 3 child threads parallel.
    This is just an example, via which I need to do computations simultaneously.
    And I also wan't to display a GUI, which gets 'not responding forever' while long computation again & again.
    I wan't the GUI to be active in this condition.
    Best Regards
    Piyush
    User: "tinh"
    Updated by tinh
    It is impossible,
    as I said, i am not sure how child threads can access hm database
    they just load an tcl interp to perform calculations, i think so.
    if you find a way to do that please tell me.
    Good luck to Piyush  :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    Altair Employee
    OP
    Dear @tinh
    I have tried hm_database access using threads, I am not able to access.
    Then, Child Thread can display a GUI, which keeps updating even with Long Calculations in Hypermesh ?
    I am not able to display GUI (eg. A button widget) using Child Thread in Hypermesh.
    Is this also possible ?
    Best Regards
    Piyush
    User: "tinh"
    Updated by tinh
    forget MT in hm, it just mess up your codes.
    simply use update command to keep gui updating
