🎉Community Raffle - Win $25
Join and Win
Changing "result type" in FLD tab for Abaqus .odb-file
Hello,
I try to plot the Forming Limit Diagram of a deep drawing process in Hyperview 12.0. As input file for Hyperview I use an .odb File, that was created by Abaqus/CAE 6.13-1. When I plot the contour in Hyperview the 'result type' dropdown menu gives me the option to select 'PE-Plastic strain components (s)' and as a result the values for plastic strain are equivalent in Abaqus and Hyperview. Unfortunatley, when I try to plot the FLD, the 'result type' dropdown menu is not giving me any choice and is set to 'PE-Global-Plastic strain components' on default. Clicking on the little arrow on the dropdown menu isn't doing anything at all. With the 'PE-Global-Plastic strain' selected I get way higher values for my FLD.
Why can't I set the 'result type' on the FLD tab to 'PE-Plastic strain components (s)' instead of 'PE-Global-Plastic strain components'?
Thanks for your help in advance.
Regards,
Fabian
1 - 9 of 91
