Changing "result type" in FLD tab for Abaqus .odb-file
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello,
I try to plot the Forming Limit Diagram of a deep drawing process in Hyperview 12.0. As input file for Hyperview I use an .odb File, that was created by Abaqus/CAE 6.13-1. When I plot the contour in Hyperview the 'result type' dropdown menu gives me the option to select 'PE-Plastic strain components (s)' and as a result the values for plastic strain are equivalent in Abaqus and Hyperview. Unfortunatley, when I try to plot the FLD, the 'result type' dropdown menu is not giving me any choice and is set to 'PE-Global-Plastic strain components' on default. Clicking on the little arrow on the dropdown menu isn't doing anything at all. With the 'PE-Global-Plastic strain' selected I get way higher values for my FLD.
Why can't I set the 'result type' on the FLD tab to 'PE-Plastic strain components (s)' instead of 'PE-Global-Plastic strain components'?
Thanks for your help in advance.
Regards,
Fabian
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Hi Fabian,
    Can you share the updates installed on your machine for HyperWorks 12.0?
    use the link below to know how to find updates: http://forum.altairhyperworks.com/index.php?/topic/13435-to-identify-the-software-updatepatch-that-has-been-installed-in-your-machine/
    If there are no updates, I would suggest you to update to the latest available patch for HW 12.0(specially for Abaqus) available from the link below:
    http://www.altairhyperworks.com/ClientCenterHWUpdateDownload.aspx?pro_cat=HyperWorks
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-80114000-1444390699_thumb.jp
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Hello,
    thank you very much for your reply. I updated Hyperworks to the latest available patch. To be sure I post the 'Updates Information' below. Unfortunalty the problem still occurs.
    Do you have any other idea how to fix the issue?
    Regards,
    Fabian
     Updates Information:
    acusolve12.0.310
    hwdesktop12.0.110
    hwdesktop12.0.125_hotfix
    hwdesktop12.0AbaqusODB6.13
    hwdesktophelp12.0.110
    hwsolvers12.0.210
    hwsolvershelp12.0.210
    SimLab12.1_hw12.0
    sT9.5_hw12.0
    vwt12.0_hw12.0
     Versions:
    hgtrans.exe:                  12.0.110.40 (Sep 13 2013)
    hmobj.dll:                    12.0.125-HWDesktop (Sep 14 2015)
    hmopengl.exe:                 12.0.125-HWDesktop (Sep 14 2015)
    hst_ng.exe:                   12.0.110.40.500186 (Sep 13 2013)
    hstbatch_ng.exe:              12.0.110.40.500186 (Sep 13 2013)
    hstdss.exe:                   12.0.110.40.500186 (Sep 13 2013)
    hvp.exe:                      12.0.110.40 (Sep 13 2013)
    hw.exe:                       12.0.125-HWDesktop (Sep 15 2015)
    hwmbdmodel.dll:               12.0.125-HWDesktop (Sep 15 2015)
    hwplot.dll:                   12.0.125-HWDesktop (Sep 15 2015)
    hwplot3d.dll:                 12.0.125-HWDesktop (Sep 15 2015)
    hwpost.dll:                   12.0.125-HWDesktop (Sep 15 2015)
    hwtext.dll:                   12.0.125-HWDesktop (Sep 15 2015)
    hwvideo.dll:                  12.0.110.40 (Sep 13 2013)
    hwx.exe:                      12.0.110.40 (Sep 13 2013)
    templex.exe:                  12.0.110.40 (Sep 13 2013)
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Hi Fabian,
    can you share the result file?
    I will check at my end.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Hello again,
    thank you for testing it on your end. I sent the .odb-File to your dropbox link from your signature.
    Not sure if needed, but this is my FLC-data (true strain):
    Minor: -0.163; -0.068; -0.013; 0.018; 0.054; 0.355
    Major: 0.388; 0.302; 0.224; 0.18; 0.189; 0.375
    Regards,
    Fabian
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Hi Fabian,
    Thanks for sharing. I will check and update to you soon.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    To be a valid FLD data type, it need to be elemental bound tensor results(in tensor format, not in component scalar format).
    Please check if it meets this criterion.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Thank you for your testing.
    I am not sure how to change the setting in abaqus to get elemental bound tensor results, but I will try to figure it out and reply if it works.
    Regards,
    Fabian
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Hello again,
    I am struggeling to find the right settings to get elemental bound tensor results in Abaqus. Could you maybe go into more detail what to do exactly, or even tell me the setting in Abaqus if you happen to know it?
    Thanks in advance.
    Regards,
    Fabian
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Hi Fabian,
    Please contact Abaqus support on how to get element bound tensors.
Welcome!
Welcome!
