Can't Work Properly With The Stretch Tool
gbzh01
gbzh01 New Altair Community Member
edited October 2020 in Community Q&A
Hi there
I choose specifically solid thinking because I do sunglasses. Now, I watched the Webinar about creating sunglasses which makes to me a lot of sense to try it. The guy is using a tool 'stretch surface' which I also have in version 2014 but I only can select the object and the target curve. He is able to select the spine curve, I can't. When I try to select the spine curve afterwards, my object gets red and it doesn't work. Does someone knows about?
This is the link to the webinar
The stretch happens around minute 10:20.
I added a screen shot of what I am able to do.
Welcome!
Answers
  • Darren_Chilton
    Darren_Chilton
    Altair Employee
    edited September 2014
    Sorry to keep you waiting so long.  Not sure how this slipped by.  I will send a video explanation shortly.
    Thanks,
  • ArjunA_22390
    ArjunA_22390
    Altair Employee
    Hi,
    Do you have a spine curve selected?
    If there is no spine curve selected and you switch from stretch axis to spine curve, the object turns red.
    Use the 'Replace' button under Spine curve in Modeling tool panel and select the curve.
    Thanks,
    Arjun
  • gbzh01
    edited April 2015
    Thanks Arjun, I tried that as well but I am still not able to do. The spine curve selection doesn't work. I understand what you mean but there is no result. Still a red object.
Welcome!
Welcome!
