🎉Community Raffle - Win $25
Join and Win
hm_getentityvalue issue
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi All,
I have to get the material id information using tcl once the user selects the elements or components in the screen. I am trying to use below command.
hm_getentityvalue comps 12 'materialid' 0;
But unable to get the information on material id. I am even okay with getting material name string.
Can someone please help me to know how to achieve this task.
Thank you,
Regards,
Prasad Poduval
1 - 5 of 51
    Altair Employee
    OP
    Hi,
    try to use:
    hm_getentityvalue comps 12 material.id 0 -byid
    Regards,
    Mario
    Altair Employee
    OP
    Hi Mario,
    I Appreciate your help. Thanks. But it is not working. Below is what i tried as per your advice.
    *createmarkpanel comps 1 'Please enter component';
    set E [hm_getmark comps 1]
    hm_getentityvalue comps $E material.id 0 -byid
    I have a material with id 1 assigned to this component.
    Thank you,
    Regards,
    Prasad poduval
    Hi,
    try to use:
    Regards,
    Mario
    Altair Employee
    OP
    Hi,
    if it doesn't work, then take the detour via property number. I have checked it, it's working...
    *createmarkpanel comps 1 'Please enter component...'
    set comp_number [hm_getmark comps 1]
    *clearmark comps 1
    set prop_number [hm_getentityvalue comps $comp_number 'property.id' 0 -byid];
    set mat_number [hm_getentityvalue props $prop_number 'material.id' 0 -byid];
    tk_messageBox -message 'CompNb: $comp_number -- PropNb: $prop_number -- MatNb: $mat_number'
    Regards,
    Mario
    Altair Employee
    OP
    Hi Prasad,
    To  get the material id from TCL Tk code is different based on solvers.  If you use PamCrash profile you can directly get it like
    But if you are using nastran profile then
    *clearmark comps 1
    tk_messageBox -message 'CompNb: $comp_number -- PropNb: $prop_number -- MatNb: $mat_number' is best.
    Which is given by Mario..
    Altair Employee
    OP
    Hi Mario/Mohan,
    Thanks for that piece of info and inputs. This was really helpful and it is working.
    Really appreciate your help.
    Thank you,
    Regards,
    Prasad poduval
