This is most likely a graphics issue. The graphics card you are using may not be fully supported. You can check whether the graphics is supported with the list attached along.
Try updating the drivers of the card.
As a workaround, try setting these enviornmental variables one by one and then together also,
HW_DISABLE_MULTISAMPLE=1 or the HW_DISABLE_FBO=1
The procedure is as below (if not using Windows 7, just Google for the procedure to set variables for any other OS)
Windows 7
Right click on My Computer from the Start menu
Choose Properties from the context menu
Click Advanced system settings > Advanced tab
Click on Environment Variables,
Click on new under the system variables section and enter the variable name and value
I use a laptop with NVIDIA GeForce 1060 Graphics card.I am still getting the same error.I cant do anything about that if Hypermesh is not compatible with my graphics card?
Hi Janarrtanan,
Windows 7
