🎉Community Raffle - Win $25
Join and Win
Problems with Fatigue Analysis
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hey guys, I’m a mechanical engineer student and I participate in a project where I analysis the structure of a modern tricycle. I need help with the fatigue analysis. I make the training of fatigue by Altair and tried make the analysis, but I’m not sure of the results. I think the problem it’s on the TABFAT.
About the TABFAT:
               My analysis has 1D and 2D elements. I obtained the following values in the Linear Static Analysis:
Analysis 1D
Analysis 2D
σ_max
24,59 MPa
267,9 Mpa
σ_min
-19,71 MPa
0 MPa
               Can I represent the load cycle of my “vehicle” like a sinusoidal curve? Can you show me how I represent it?
              Should I represent these values for each of the fatigue analysis like one analysis for 1D elements and other analysis for 2D elements? Can I “mix” these values for the two analyses representing σ_max = 24,59 MPa and σ_min = -19,71 MPa?
               I think that a correct method is consider my load cycle like a variable load, but I don’t obtain experimental data.
About the MATFAT:
               I acquired the MATFAT data by the eFatigue website, but I don’t obtain the SE (standard error of log(N)). How I find out this? If I consider SE like “Default” (zero), how will affect my analysis?
Note: I’m making a SN analysis.
Thanks for helping!
