Error while importing .fem file in Altair flux
User: "Divin Pulakudiyil  Xavier"
Altair Community Member
Updated by Divin Pulakudiyil Xavier
Hi,
I am trying to import a .fem (optisturct as user profile) file to the Alair flux using import mesh from a HyperMesh/SimLab/Optistruct(Nastran) and it throws an error.
Any help?
Thanks
1 - 3 of 31
    User: "Mohammed Elamin_22169"
    New Altair Community Member
    Accepted Answer
    Updated by Mohammed Elamin_22169
    Hi Divin,
    Not sure if you check this document from the help, It might be helpful.
    In general, please check the conformity of the mesh and make sure there is no free nodes and edges, intersection,...etc. as Flux will not accept those defects. Also make sure your model had the meshed bodies only and you should remove any solutions, BC  or load settings.
    The error is very general and it is not helpful to know what is source of the problem. If possible can you share fem file of concerns (this public forum). If not then I will encourage you to open a support ticket.
    Thanks,
    OP
    Hi Divin,
    Thanks,
    Hi Mohammed,
    Thanks a lot for the answer... I was able to import the mesh
    OP
    Hi Mohammed,
    Is possible to import infinite box as well... because I dont see an option to assign face to infinite box?
