Rigid wall velocity
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hey every one,
I'm doing a crash test using a rigid wall with an initial velocity.
How can I get the velocity of the rigid wall?
I would like the curve of the velocity (or position or acceleration) of the rigid wall with hyperview.
Here is my Engine file:
#RADIOSS ENGINE
/ANIM/DT
0 0.2
/ANIM/MASS
/ANIM/ELEM/VONM
/ANIM/VECT/CONT
/ANIM/VECT/DISP
/ANIM/VECT/FOPT
/ANIM/VECT/ACC
/ANIM/VECT/VEL
/ANIM/VECT/PCONT
/RUN/shell_solid/0/
60.0
/TFILE
0.5
/VERS/110
/PROC/2
Thank in advance,
Robin
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited February 2016
    Hi Robzim,
    try this:
    Create an output block for the node of the rigid way and edit the same to define velocity output. Here is a link which discusses on how to output reaction force using REAZ definition.
    Instead use VX/VY/VZ to get the velocity for the node. All the output information will be written to T01 (time history file) and you can use that to plot using HyperGraph.
Welcome!
Welcome!
