Altair RISE
Nominate Yourself Now!
Hyperview - Use component/model color for no results
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Under Preferences > Options, you can click and unclick the 'Use component/model color for no results'.
Does anyone know how to turn this option on/off with a tcl script?
1 - 2 of 21
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi,
    There is no exposed API to do this right now.
    User: "tinh"
    Updated by tinh
    Hi,
    There is no available api
    But by dumping the check box, I see its state variable is:
    ::post::optionsdialog::usepcolor
    you can set it equal true to turn on and false to turn off the check box
    after set it, you must call:
    ::post::optionsdialog::OnButtonPressed 0
    because actual state variable is hidden and if you don't call that proc, it will restore the above variable!
    (this is called as you click 'Apply')
