🎉Community Raffle - Win $25
Join and Win
Query in Split Element using Curve/line
Hi,
I am writing a script for automating blot assembly creation.
Some components like washer is having slot (OB Round) hole.
Initially I am creating 2D mesh and later I will drag it for each component.
Please find attached the image for understanding my query.
I have considered one quadrant and creating the base mesh. And then creating ruled mesh for each layer.
After creating the mesh, I want to split the elements using slot profile.
After splitting, we should maintain the Slot profile exactly.
And mesh should contain Only Quads.
But I am not getting right way to do this splitting
Please suggest a way to do this.
If any alternative methods are there for this type of mesh creation, that is also welcome.
Thanks in advance.
Regards,
Hari Krishnan. EL
<?xml version="1.0" encoding="UTF-8"?>post-36330-0-94005300-1425045355_thumb.p
<?xml version="1.0" encoding="UTF-8"?>post-36330-0-83918500-1425045356_thumb.p
1 - 6 of 61
