🎉Community Raffle - Win $25
Join and Win
How to remesh for 20mm to 50mm for a big model?
User: "Stalewad"
Altair Community Member
Updated by Stalewad
I have a model with 2 million elements. The element size is 20mm now. I need to remesh it to 50mm size.
What is the quickest way to remesh the whole model easily?
1 - 7 of 71
    User: "Mario_21478"
    Updated by Mario_21478
    Hi stalewad,
    you can still use the automesher and select elements for meshing.
    Set your new mesh size, check the feature and vertex angle, set connectivity and mesh. Maybe you can't do it interactive, in this case switch to automatic.
    See following picture:
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.20bdb2ff468e4bba74322642ed6c7031.png
    Following simple example is done in 10 sec.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.4bcec065031e70def4e0790148e8a0b4.png<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.431b6a67a18b50c6ff8859f88f0d3106.png
    Best Regards,
    Mario
    User: "Stalewad"
    OP
    Updated by Stalewad
    Hi Mario,
    I have done this step. Components loose the connectivities (mesh connectivity) at many locations. Manually reconnection is very time consuming and almost takes equal time of meshing.
    I am looking for any innovative idea to keep the connectivity and generate the good mesh as parent mesh.
    Regards
    User: "Mario_21478"
    Hi stalewad,
    if you stay with keep connectivity, it will be normally fine. Otherwise often the original mesh is not 100% connected.
    For me it works also very good for a lot of elements, but 2 millions is quit a lot for this task.
    Best Regards,
    Mario
    User: "Stalewad"
    OP
    Updated by Stalewad
    Hi,
    I have an idea to keep connectivity.
    I have generated 1D rod elements between all the components and selected adjacent elements and remesh. This will keep your connectivity and generates bigger elements at the interfaces. again remesh remaining mesh by reversing.
    Regards
    Shreekant
    User: "Stalewad"
    OP
    Updated by Stalewad
    Hi,
    So this is the improvement topic for ALTAIR. keeping the connectivity while remeshing.
    Regards
    Shreekant
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    if your model is correcly connected, usually HM keeps your connectivity through remeshing, as Mario's example.
    It looks strange losing connectivity like this.
    Can you show some pictures in details where it lost its connection?
    User: "Stalewad"
    OP
    Updated by Stalewad
    Hi Adriano,
    I can not share any pictures, it was office work and as per data policy.
    Regards:
    Sri
