Altair RISE
Nominate Yourself Now!
Hypermesh 2024 USER interface issue: the Modeling Window doesn''t show.
User: "Peiye Lu"
Altair Community Member
Updated by Peiye Lu
Dear
My computer installed 2021/2023/2024 version hypermesh.  The 2024 version hypermesh modeling window doesn't display anything, Pls see below picture. The model and default coordinate system don't show on modeling window zone.
After I restarted and reinstalled hyperworks, it did work, how can I solve the issue?
1 - 1 of 11
    User: "Michael Herve"
    Altair Employee
    Updated by Michael Herve
    Hello,
    there are a couple of points you can check:
    - make sure your graphic board driver is up to date. If not, install the latest driver with custome mode, and check the option for running a clean instllation (the installer will remove previous installer files)
    - some files generated by HyperMesh can cause such glitches. You can run the script in C:\Program Files\Altair\2024\hwdesktop\Utility\HWCleanUp
    Hope that helps,
    Michael
