Hi, I want to make a linear static analysis where the force start with load of 10 N and arrive at 100N. The increasing step is 10 N. Is it possible using one load step? If yes, can you explain me? Thanks
Hi Saverio,
You can run a NLSTAT analysis instead, where the load will be divided in to steps.
Please refer to OptiStruct help for more information.
