I can't choose card image when I create a ply, it doesn´t show me options.
How can I do to see the options?. Thanks,
Pedro
Could you let us know the user profile you are using?
Hi Rahul,
My user profile is RadiossBlock (Block120 Format)
Thanks in advance.
Hi Pedroi,
Instead you can create plys using PROP/PLY property and stack using PROP/STACK.
I have the same problem. I want to create a laminate in RADIOSS but I do not know how the process should be.
What I do is:
Create à ply
(I create as many plies as I need, although I cannot put the card image “PLY”)
Then, Create àLaminate
(There, I select each of the plies but I cannot select the card image “STACK”)
In this moment, I do not know if the laminate is well created and how I can assign it to the piece.
Is there any kind of tutorial?
Thanks,
Gabriel
@Gabriel CP
Use PROP/PLY and PROP/STACK instead of creating via ply and stack in model browser.
