If after I create a Pressure load using surfaces option I have gone to loads on geometry and mapped the loads.
My question is after this do we have to delete the loads that we created on the surface?
Thanks,
Datta
the load on surf has EID=0. I think you don't need to delete it
It seems to be unnecessary to map loads in hm14, they will be mapped when you export fe model
