Hello Friends,
I am building a fatigue analysis in which case the damage is super high, i suspect it is because the model is cyclically loading what should be constant preload in another region of the structure i am analyzing.
Does anyone have instrucitons on how to seperate a constant load from a cyclic load in a linear static subcase that the fatigue subcase references?
Thank you!
Jason
