I am creating a rope and pulley arrangement. Now, I wish to place the pulley boundary conditions such that it only rotates. Can you tell if the boundary condition is right because as per my understanding I need to define another coordinate system at the center of the pulley about whose z axis should it be able to rotate. So I am guessing the current Placement is wrong.
2) The pulley's only purpose is it should rotate and remain rigid. Should I still define the meshing and everything else on it. As I want it to remain rigid and rotate.
3) As I am using the integrated beam in the beam pic. I am using the reference guide of Radioss to input the values. It states local coordinate. which coordinate system is it talking about. Is the local coordinate system present for each individual part like the pulley and beam?
yours sincerely,
kartik kanugo
