Hi
im trying to see the results of my analyses but i can, anyone i try shows the same error, even though the same files and analyses has already been run in another computer,
Could you tell me how to fix it? heres the message:
thank you.
Can you share the error message?
Are you trying to open result file (.h3d) in HyperView or in any other clients?
im sorry, i thought i had uploaded the message error.
im trying to open the result file (.h3d) in HyperView
heres what it says:
I see message log has some warning. What happens when you close message log?
Nothing happens, the results still do not appear. what should i do or what im a doing wrong?
Did you try to plot results using contour plot option in Hyperview?
