I am trying to do a simulation with prescribed body motion.
I referred the two links mentioned above to do my simulation and my simulation was a failure.
There is no displacement when viewed in the h3d file.
These are the screenshots of what I basically did:
The node at the end of the system has been assigned a local coordinate system and SPC, SPCD pair has been defined at the same node.
Another issue I noticed was that the SPCD always resets itself to 0. (I want to define 30)
Thanks in advance!
