Negative area: Delete connection solid element
I am doinga calcul in Hypermesh using thecomposite resin model, ther qre no errors when I execute the solver qnd the cqlcul turns properly, however I find this messeges that I am not sure what they mean. Can you help me please?
160000 0.3571E-01 0.2303E-06 NODE 100096229 -28.9% 0.2627E+05 417.3 0.000 0.3755E+05 0.000
NEGATIVE AREA: DELETE CONNECTION SOLID ELEMENT 100079203
NEGATIVE AREA: DELETE CONNECTION SOLID ELEMENT 100065193
NEGATIVE AREA: DELETE CONNECTION SOLID ELEMENT 18947
165000 0.3677E-01 0.2136E-06 NODE 100046689 -29.4% 0.2757E+05 354.3 0.000 0.3954E+05 0.000
NEGATIVE AREA: DELETE CONNECTION SOLID ELEMENT 18631
NEGATIVE AREA: DELETE CONNECTION SOLID ELEMENT 100065321
170000 0.3781E-01 0.2327E-06 NODE 100096229 -29.7% 0.2931E+05 480.6 0.000 0.4238E+05 0.000
NEGATIVE AREA: DELETE CONNECTION SOLID ELEMENT 100049157
175000 0.3885E-01 0.2036E-06 NODE 100096229 -30.0% 0.3168E+05 851.7 0.000 0.4646E+05 0.000
NEGATIVE AREA: DELETE CONNECTION SOLID ELEMENT 100086172
ANIMATION FILE: LGPC1.2_base_res_4.hfA010 WRITTEN
Thanks!! /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Could you share complete out file with us?
