Size Optimization
I have attached model here that I want to optimize .
This model has 3 regions. 1-> 17 plies each 0.02' thickness. 2-> core ply of 0.3' and 3 plies both sides of 0.02' thickness. 3-> core ply of 0.6' and 3 plies both sides of 0.02'.
3 PCOMPP are used for above 3 regions.
The maximum deflection from static run is 0.0191'.
My aim is to limit the deflection to 0.010'.
Constraint : Ply shape and ply thickness should not be changed.
We can add plies with same shape and same thickness.
Do we need to link design variable for 3 different PCOMPP? If yes then what should be the approach for that.
Please guide me the procedure of the optimization to solve this problem.
Thanks in advance.
