Is there a way that I can read Radioss files with Matlab or Phyton? Can I output the values to have it in ascii? I read something about the command /TFILE/3. However, adding this to my engine file doesn't change anything.
Best, J
I don't think it's possible, but I'll check regarding this and will update you.
From the time history file (/TFILE) you can plot the curves in HyperGraph and those values you can export from HyperGrpah in .csv format.
Hi George,
Did you hear any update regarding this topic?
Best, Jonas
Hi Jonas,
Apologies for a delayed response.
/TFILE/3 is an obsolete option now and we don't recommend the same.
The workaround for this is to use binary format for T01 file and convert it to the required format from HyperGraph.
