law for multi-usages
Hello !
I have a model in which a material could be submitted to compression and tension.
However, this material have different reaction for these different solicitations.
I wonder if a law which detect the kind of constraint and adapt the reaction exists ?
Thank you for your answer !
Can you please elaborate more on your project, that is the objective of your analysis.
0 -
I have an object and I want make different test on it (tensile test, compression test or flexion test).
I have constitutive law for compression and tension (law 44) which are different and I want only one law.
For example, if i shot on it, I wish that my new law use my compression law and my tensile law where that happen.0 -
What kind of material do you have (metal, plastic, foam …. )?
0 -
It's a bone.
But they are two kinds of material : a foam and an elasto-plastic0 -
For foam materials, you can use LAW38 or LAW70.. For elasto-plastic materials, you can use LAW66.
Please go through the Help Menu on these material cards.
0 -
This law does not seem to work for shell elements.
Do you have a law for that ?0 -
You can model with /MAT/LAW36, where fct_IDp is used to distinguish the behavior in tension and compression for materials.
Please go through the Help Menu on the same.
0 -
This law is great thank you !
But I don't understand how to define compression curves and tensile curves.
Must I define them together ?
0 -
Yes, define the material behavior and call the function in fct_IDp.
Meanwhile, /MAT/LAW66 is compatible with shell elements also, which is an isotropic tension-compression elasto-plastic material law.This law can be defined for compression and tension.
