Hi I am trying to render, but it always terminates early.
whats the best configuration to set it at so that i can photoshop it and present in a days time.
I at least want smooth curves.
Cheers
Hi Damian,
Check the rendering method used under Rendering properties. The raytracing method is very fast and often completes in a few seconds. The full progressive is sample based and the default is 500 samples. Try that and let us know.
Btw, 'Rendering Terminated' is a terminology that we have change for the future releases. We realized it gives the wrong impression.
