Hi all,
Is there any example about tensile test simulation? I don't know how to output section force to compare with experiment's force.
Thank you
Roy
R efer the attached image. There is tutorial available. For more details refer help
In OptiSrtruct OS-E: 0110 Elastic-Plastic Large Displacement Analysis
Hi, R efer the attached image. There is tutorial available. For more details refer help <?xml version="1.0" encoding="UTF-8"?>
Hi gopal_rathore,
The example you mentioned is solved by using Radioss solver (explicit method). However, for a quasi-static tensile test (the velocity of tension is about 5mm/min), I think we cannot solve it with explicit method. I want to find some tensile example with implicit method by using optistruct. I think this may be more suitable for this low tensile test. Do you think so?
Hi, In OptiSrtruct OS-E: 0110 Elastic-Plastic Large Displacement Analysis
Hi Prakash,
I cannot find the example you mentioned. Could you please share the pdf file?
Here you go...
Thank you for the pdf file. Could you please share the model with .fem input file? Maybe this example is only in the latest version. My version was only 13.
Anyone can share the model with .fem input file format?
Hi @Roy Duan
PFA,
