Hey Everyone,
I'm try to simulate a conveying rig in MotionView and need the belt to be flexible and allow contacts to rigid bodies at areas that aren't joints. I've looked into using flex bodies and NLFE's and from what I can gather the only way contacts can be specified between flexible and rigid bodies is by attaching many small rigid bodies to the flexible body with fixed joints, then specifying contacts between those bodies and the other bodies in my model.
I'm also planning on using the coupled MBD-DEM feature later on and also need to know if a flex body can interact with the particles that I generate or whether the same rigid to flexible contact problem will be an issue.
Is there another less complicated method for solving this problem that you would suggest??
Many thanks!
