ERROR ID : 482
I am doing an analysis in radioss. I want to find the required force to install the clip in a sheet metal. I have done all the setup but I don't understand why it gives me this error. i appreciate if some one can help
ERROR ID : 482
** ERROR IN INTERFACE DEFINITION (MASTER SEGMENT)
DESCRIPTION :
-- INTERFACE ID : 2
-- INTERFACE TITLE : edge
CANNOT FIND ELEMENT OF MASTER SEGMENT ID=114
Please check the interface created. Select the master elements and update in the interface menu and click review to cross check that the interface is correctly defined.
0 -
I have done so. I just sent you my file I appreciate if you can check it.
0 -
Please check the updated model.
0 -
Hi George
Thanks a lot for your help but this file doesn't go through the run process. There is no error but I couldn't run the model. I have version 14 on my PC.
Please see the .out file from the file you sent me.
0 -
Thanks a lot. the new file is working. i will update you with the results
