Hello All,
Greetings!!
I am using mm, kg, ms units system in HyperCrash and using Mat Law 36 or PLAS_TAB for different parts.
Therefore I have taken strain rate unit as 1/ms.
But general standard unit for the strain rate is 1/sec. Therefore I ran simulation with units as 1/sec as well.
Results: Simulation results of Strain rate with 1/sec units are closer to experimental results as compare to 1/ms simulation results.
Above screen shot is from Radioss_10.0_Reference_Guide2.
Please guide me what unit (1/sec or 1/ms) to use for accurate material modelling in Radioss.
Thanks and Regards
Nitin Jain
