I want the stress and displacement in a component due to change in temperature i.e the deformation due to change in temperature by 40 degree Celcius. How can this be done am not getting the option for temp diff.
Hi Kushal,
You can do a thermal analysis, refer to this below tutorial on OptiStruct guide.
what is the default unit of coefficient of thermal expansion in properties used to define material?
Khushal,
There is no predefined unit system. You need to maintain a consistent unit system.
